Owning a car can be very expensive. Especially when you factor in all of the monthly costs, like fuel, insurance, and more, it’s not only the actual price of the car that you should be concerned with. But luckily, with proper planning and maintenance, you can avoid some of the biggest expenses that often come with car ownership: emergency repairs.
So to help you avoid having to pay a ton of money when something breaks down with your vehicle, here are three car maintenance tasks you should do every month to keep your vehicle running smoothly and safely.
Checking Or Changing Your Oil
Checking and changing your oil is one of the easiest and most important things you can do for your vehicle on a regular basis. Without the proper oil, your vehicle won’t be able to function as it should, which could lead to major issues with your engine and huge repair costs.
According to DefensiveDriving.com, while you really only need to change your oil every 3,000 to 5,000 miles on average, it’s always a good idea to check your oil much more often. By making it a habit to check your oil at least once a month, or even every time you fill your car up with gas, you’ll be able to know if you’re running low on oil before things get too far.
Examine Your Windshield Wipers
Car repairs can not only be brought about by something breaking down in your vehicle, but also by you getting into a car accident as a result of not taking proper care of your car. One way to avoid this is to make sure that you’re always using windshield wipers that keep your field of vision clear.
David Bakke, a contributor to Money Crashers, shares that if your windshield wipers start streaking or squeaking, you’ve let them go too long and are in desperate need of changing them. So to make sure you never find yourself in a situation when you need to be using your windshield wipers to see but they aren’t working effectively for you, it’s wise to examine them once a month to make sure they’re still holding up.
Check Your Tires
The quality and stability of your tires have a huge effect on how safe your car is on the road. And because replacing all of your tires at the same time can be very expensive, you should be checking your tires on a monthly basis to ensure that you are doing the proper preventative maintenance on them.
According to Alan Henry, a contributor to LifeHacker.com, you should plan on checking the tread and tire pressure each month. By doing this, you’ll be able to see if you need to get your tires rotated or if there’s an issue with anyone tire that you should then replace.
If you want your vehicle to last a long time and to save money over the duration of your car ownership, consider implementing the preventative maintenance tasks mentioned above.
